Thread: Vastly diluted bleach may have a ptrotective effect
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Vastly diluted bleach may have a ptrotective effect
    0.005% concentration of sodium hypochlorite would be 47.6 ppm FC so I don't know why they say this is lower than found in swimming pools. And that is with no CYA in the water. They are also wrong about it not being a disinfectant at such concentrations. Most common bacteria are killed faster than they reproduce when the equivalent FC with no CYA is only 0.001 ppm. Planktonic bacteria including Pseudomonas aeruginosa on the skin and fecal bacteria are generally very easy to kill. This is why having the FC equivalent of only 0.1 ppm results in 3-log reductions in 1.5 minutes or less which is equivalent to a 50% reduction every 9 seconds.
    The paper itself has not yet been published, but this link is a better one with more accurate information and does not make the claim that the 0.005% is more dilute than swimming pools nor that it isn't a disinfectant at such levels. Geez, leave it to mass media to simply make stuff up!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,049
    Yeah, I was just gonna post that.
