Results 1 to 10 of 10
Thread: Which is best SWG?
    Which is best SWG?
    I'd like to install a SWG over the winter. Is there any consensus on which is the best? I'm thinking of getting the Pentair. Anyone know of negatives on its use versus other SWGs? Amazon sells the Pentair power center 520556 and the IC40 as separate units. Is this all that is required? Thanks for any input you can give.
    Dean
    docelect
    30k gallons in-ground vinyl
    1.5 hp pump 300 lb sand filter
    Polaris cleaner, T15 Hayward SWG
    Jackson, Mississippi
    Aug 2010
    Dallas, TX
    4,052
    Re: Which is best SWG?
    You will hear pros and cons for all of them. If you want to go automation at some point, get all the same brand, like all Pentair. Pentair has great support, but be warned they are considering dropping support for items bought mail order, including Amazon.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Quote Originally Posted by docelect
    Dean
    I have the Pentair IC40 SWG and yes, the power center and cell is all there is to it.
    The controls and indicators are on the salt cell itself and covered by a tinted slide off plexiglass (or whatever type of plastic) cover.
    Divin Dave,
    38,305
    Without full automation, isn't the Pentair limited to 20% output increments? This could make it more difficult to dial in the correct output.
    I have an AutoPilot PoolPilot Digital. If I was buying a new salt generator right now, I would likely buy this one:
    http://www.inyopools.com/compupool-cpx- ... rator.aspx
    27' round Above ground w/sand filter
    17100 gallons calculated
    Nashville, IL
    Sep 2012
    Lake Nona, Florida
    386
    yes - we have an IC-40 and Jandy automation. It is limited to manual selecting 20% increments.
    The guy who spec'd it said the Pentair was enough better that this restriction was worth the tradeoff.
    We have been able to keep FC basically OK, mostly.... we change from 20 to 40 and back every so often.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    Thanks to all for the replies. I have been looking at the Aqua Rite and the Compu Pool as well as the Pentair. The Pentair says the cells are good for 10,000 hours, but I don't find any rating for the Aqua Rite or the Compu Pool. What have real-world user experiences been for these 3 SWGs? The Compu Pool is low priced, but I see a lot of negative reviews on Amazon's site. The downside of the Aqua Rite seems to be periodic replacement of the control board. I'd be interested if anyone has experience they could share.
    Dean
    docelect
    38,305
    Often the Hayward does not need a new board, it just needs a new current limiter soldered on ... only costs a couple bucks.
    I have found the AquaRite to be a good SWG.
    Support the site
    May 2013
    Fort Lauderdale, FL
    423
    Pool pilot nano + here. Ran it all summer and installed myself. I highly recommend it.
    Make sure you price replacement cells. Pool pilot ones are nearly half the cost from www.saltpoolguys.com vs the MSRP listed on their website. I bought my system from them.
    Do some reading- I read about lots of compu-pool issues here on the forum.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
