Thread: Brand new intermatic freeze timer issue
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    i just installed a brand new intermatic PF1102T.
    the clock is not running on it .
    i can turn it on and off manually , and pool SWG Heater and pump work fine.
    The time in the window never changes.
    i measured the voltage at the 2 pins on the side of the motor and i have 110 volts on each pin
    Non of the visable gears appear to be turning.
    The motor case is not warm
    looks to me like a bad motor did i miss somthing ???
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Re: Brand new intermatic freeze timer issue
    I might suggest you call Intermatic Customer Service/Tech Support. They were very helpful for me when I had a product question for replacement. Good Luck!
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    yea gonna call them in the morning ..
    thanks..
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Turned out the clock motor was bad . I called intermatic and they sent me a complete new module !!!
    It fixed it.
    Sean Hannon
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    This just happened to me. Just had mine installed a month ago, although it is a T101P mechanical timer. Thought it was the timer motor as well... until I realized that the GFCI outlet on the same circuit was tripped. Reset the outlet and timer was keeping time again. $0 fixes that make me feel silly are just fine.
    Isolated Spa - 345 Gallons
