Thread: Leaf Stain?
    May 2012
    Flower Mound, TX
    130
    Leaf Stain?
    Today just notice two leaf stains bottom of pool while I was removing some leafs. Tried to remove stain with brush, no help. I have the filter on for 3 hrs a day, and cleaner for 2 hrs a day. I didn't realized that a leaf would stain a pool that quick, I remove leafs every day, if not every other day.
    Pool temp. is 64 degrees, I would hate to jump in and try to scrub with green pad
    Any suggestions in removing stain, Pool chemical reading as of 15th Nov:
    FC: 2.0 (added 21 oz. of bleach)
    PH: 7.8
    Other chemical reading as of 4th Nov:
    CC: .5
    TA: 70
    CH: 340
    CYA: 40
    I just never seen that before!!
    John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Leaf Stain?
    If you keep FC at the high end of the range, it will likely fade away in a few months. If you want to try speeding it up, set a trichlor puck on it and then check it every few minutes.
    May 2012
    Flower Mound, TX
    130
    Re: Leaf Stain?
    Rich,
    Do you suggest during the fall season I keep my FC target on high end (CYA chart: 5) to prevent leaf stains?
    This is my first year for fall with the pool. I'm afraid to use a puck on it, because to much Football and Nascar on TV to monitor the puck
    In mean time I will get new FC readings during commercial and bounce off the calculator and readjust to high end. Thanks
    John
    May 2012
    Flower Mound, TX
    130
    Re: Leaf Stain?
    New reading FC: 2.5
    Adding 53 oz. of bleach to reach my target of 5ppm. I thought I would save some money on bleach to keep FC on low end during fall & winter, but now I'm thinking to keep on high end during fall and low end during winter.
    Still planning on using the spa during fall & winter. Thanks
    John
    Richard320's Avatar
    Jan 2010
    19,067
    Re: Leaf Stain?
    Quote Originally Posted by JohnH
    Rich,
    John
    It won't prevent organic stains, but it will bleach them out. Don't let the leaves sit there and you won;t get stains.
    In cold weather, you'll find chlorine loss is pretty low, so keeping it at the high end of recommended won't use very much extra bleach.
