Thread: What is the best skimmer for my pump size
    Nov 2013
    Christchurch, New Zealand
    7
    Hi everyone
    I have done a bit of reading about surface skimmers and want to buy one for our pool.
    Comments have been about making sure your pump is powerful enough for the skimmer.
    We have Sand Filter that came with our ultra frame pool but a skimmer was not included.
    The Sand Filter is Intex Kyrstal Clear Sand Filter Pump 12" Model SF10220, it says maximum flow rate is 4,000 litres per hour ( 1050 gallons per hour).
    Some people have put through wall skimmers but would our pump be powerful enough for one of those?
    Or is our pool (16' x 48inch ultra frame round AGP) better suited to a Wall mounted surface skimmer and if yes is the Intex Deluxe Surface Skimmer the way to go or another type of one.
    It will also depend on if we can get the product in New Zealand or not.
    Also I saw someone on here saying they had a surface skimmer but it didn't work too well as their kids jumped around a lot in the pool which is what our kids will do, so will the surface skimmer still do its job?
    Sorry for so many questions but two weeks ago I had never owned a pool, it's a steep learning curve!
    Thanks
    Actually we also don't have any type of vacuum system so if we got the surface skimmer should we get one of those types that attaches a hose into the skimmer inlet or is a standalone separate vacuum the way to go?
    Intex Ultra Frame Round Pool AGP 16' x 48" 19,156 litres (= 5060 Gallons) (we are metric in NZ!)
    Sand Filter 12" Maximum Flow Rate 4,000 litres per hour (1050 Gallons/hour)
    Intex Deluxe Maintenance Kit including surface skimmer and vacuum
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: What is the best skimmer for my pump size
    A through the wall skimmer will work best but it is more work to install. Your pump should be fine for a wall mounted or surface skimmer. Have you seen [url=http://www.troublefreepool.com/useful-links-for-fellow-intex-pool-owners-t29612.html]? Reading through these links may give you some ideas for your pool.
    I believe if you use the surface skimmer you will need a separate vacuum, such as an aquabroom.
    Love TFP? Become a
    TFP Supporter!
    Nov 2013
    7
    Thanks for your reply. No, being new to all this and new to this wonderful forum, I didn't know about that link, so will go and have a read.
    Nov 2013
    7
    Forgot to also ask, we have two inlets that go to the pump, so when you hook up the skimmer into one of them, what do you do about the other one? Do we just not worry about it or do you have to block it off? And how do you block it off? I can't just turn off the plunger valve as that controls the inlet that the skimmer would be coming from.
