Thread: Pool mess
    Pool mess
    A couple of months ago my salt system failed and the pool got completely out of hand. The pool was as bad is can be
    Fibreglass in ground 12000 gallons.
    Drained pool and there were bad stains and some black algae used pressure washer and it does nothing to remove stains. I know acid is no-no, any ideas??
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pool mess
    Can you put your pool equipment/specs in your signature?
    Sounds like it was overrun with algae and you need to go through the SLAM process. If it's black algae, you'll have to use a little elbow grease and scrub it while SLAMing.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool mess
    Quote Originally Posted by JeffW
    Based on the information in your post about the SWG failing which would lead to low FC levels, black algae is a distinct possibility. If it is indeed black algae, brushing is just as important as elevating the chlorine level. Black algae forms a protective film over itself and this film needs to be broken down so the chlorine can get at the algae itself. I would brush the surface twice a day. Also, if you have a pool light, I would disassemble and clean out the niche. Same goes for any ladders or removable steps, if applicable to your pool.
    Any way you can post a pic? Since you mention "bad stains and some black algae", it is possible some stains could be metal-based. This may be a bit of a long-shot, but I'm going to put it on the table: I have read a few posts where "overspray" from granular lawn fertilizers/treatments containing iron can also result in "black dot" stains that look similar to black algae. Any chance this could have happened in your case? A quick way to rule out metal stains is to take a vitamin C tablet and gently rub it on the stain for about a minute. If it fades, then it is a metal stain.
    Re: Pool mess
    I ended up completely draining the pool. taking apart filter and cleaning it. I also cleaned out all the pipes. I then sprayed pool with bleach and washed off. I scraped the black algae and hope that I got is all. Refilled pool and it looks good. Will wait till spring to tackle salt system.
    30,426
    Re: Pool mess
    Good work. Keep chlorine in there all winter or some of your hard-earned progress will be lost.
