Results 1 to 13 of 13
Thread: Why would they wire it this way?
    May 2013
    Dallas area
    85
    Hello - I have an intermatic pf1202t timer running a pump for an auto a kreepy krawley and a swg. They wired it so the timer on the left turns on the swg and is in series with the timer on the right for the pump. Therefore to run the pump, both timers need to be on. For the most part the swg runs more than the cleaner pump so I just overlap them. But now we are heading into winter and I was going to shut the swg off. I cannot do this through the timers since they both need to be on to run the cleaner pump. I can set the swg at 0%, but this does not shut the pentair swg off, the flow switch still looks for flow and if the main pump is not on, it just keeps trying. I thought about rewiring it but man are there a lot of wires. I could just let if go and let the swg come on at 0% or I could remove the swg fuse or unscrew the swg from the could from its power supply but this leaves the swg connection exposed to the elements.
    What are you thought?
    Thank you,
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    22,542
    Re: Why would they wire it this way?
    What turns on the main pump?
    May 2013
    Dallas area
    85
    It is a pentair variable speed pump with its own program
    22,542
    Does an automation system control the pump or is it stand alone?
    Sorry for all the questions, but I'm trying to figure out the best solution for your issue.
    May 2013
    Dallas area
    85
    The pump is stand alone.
    22,542
    So the timer just runs the swg and the second timer, and the pump runs on it's own timer?
    I'd be afraid that it would get out of sync.
    May 2013
    Dallas area
    85
    Left timer runs the swg
    Right timer is in series with left timer and runs the pump for the robot. Therefore both timers need to be on to run the pump.
    22,542
    Maybe I'm misunderstanding. Do you have a main pump, a swg, and a booster pump for the cleaner?
    May 2013
    Dallas area
    85
    Yes
    22,542
    So the main pump runs on it's own program?
    Then the swg runs on the first timer?
    Then the booster pump runs on the second timer?
    If all that's correct, they have the timers wired as if the main pump ran on the first timer.
    Have you recently changed from a non-vs pump to the vs pump?
    May 2013
    Dallas area
    85
    The main pump runs on its own program
    The swg runs on one timer
    The booster pump runs on the second timer but this is in series with the swg timer. In other words, the booster pump cannot run unless the swg is on no matter how it's timer is set.
    No, this was a new install this summer.
    Thank you,
    Anthony
    22,542
    They set it up as if the main pump ran off the first timer with the swg. That's a normal install when you have a non-vs pump and the second timer in series keeps the booster pump from running unless the main pump is running. The vs pumps don't get hooked to the timer so it makes the normal setup not make sense when connected like yours.
    It would have been nice if the pump mfg's would have put a set of dry contacts out of the drive to send the run status to a timer or relay. But they didn't.
    May 2013
    Dallas area
    85
    Well, that explains it. Thank you for your help, I think I will rewire it.
    Thank you,
    Anthony
