Thread: Pumis stone to remove tile scaling?
    Jun 2013
    Southwest Arizona (Yuma)
    125
    I have some pretty bad scaling on my tile. Im getting ready to do and acid wash on the pool but im not sure the acid will remove it all. I ran into a pool contractor at my local Leslies yesterday who told me to try to scrub it of with a pumis stone? Has anyone done this before? I dont mind using a little elbow grease I'm just wondering if it works?
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Re: Pumis stone to remove tile scaling?
    Yes, it works. It sounds awful when you're doing it, too. You'll swear you're grinding the glaze right off it, but it doesn't appear to harm the tile at all. It also works to get rid of the calcium line in the toilet bowl.
    Jun 2013
    125
    Where the heck do you get a pumis stone at I havent seen these thing around in years?
    My pool:
    Richard320's Avatar
    Jan 2010
    18,982
    Quote Originally Posted by JT2006
    Hardware stores. Pool Stores. Check the houseware aisles, they use them for scrubbing restaurant grills too.
    I found this at the 99 Store. Waaaay cheaper than anywhere else. http://www.uspumice.com/pages/pumie-directions.html
    Jun 2013
    125
    Thanks Richard!
    My pool:
