Thread: Should SWG cell be removed in winter?
    Should I remove the cell in the winter when the water temp. is too cold for the SWG to operate?
    Dave
    Northern California
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Should SWG cell be removed in winter?
    I think if you are closing the pool then you might as well bring it in. If you will run the pool all winter, I would just leave it out there.
    Nov 2011
    Magnolia Texas
    80
    I just turn my swg on and leave it there when the water temp hits 55F. However, being in Houston we run the pool circulation all year around
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    I bring mine in and carefully stuff plastic garbage bags in the open plumbing to prevent the ubiquitous mouse and/or chipmunk from using the openings as home for the winter!
    Bosqueboy in Virginia
    In-ground 20,000 gal vinyl Grecian, Hayward Star-Clear Plus C1200 cartridge filter, Hayward 3/4 HP Superpump, AquaRite salt water chlorine generator, Heat Siphon C575HP heat pump and Blue Diamond robotic cleaner.
    Nov 2011
    Magnolia Texas
    80
    Sorry, I meant to say turn it off when the water temperature hits 55F.
    DE Filter
