Results 1 to 10 of 10
Thread: Filling a pool
    Filling a pool
    How long does it take to fill an 18000 gallon pool with water?
    Thanks
    27100 gallon in ground Pool/Spa, SWG, Pebble Sheen-Aqua Blue, (All Pentair Equipment) Pentair VS Pump, Cartridge- filter, build completed Dec. 2013, Houston, Texas
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Filling a pool
    How long is a piece of string ?
    Depends on the flow rate of the fill. If you can find that out, let us know. Very simple after that. Use the source to fill a 5 gallon pail, get back to us, or work it from there.
    Essential Links:
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Filling a pool
    With a hose, or from a water truck? I filled my pool (approx 27k) gallons with 3 trucks, each of which took about 45 minutes to empty. I was then able to bring the water level up 2 more inches with my hose (strong pressure) in about 4 hrs.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    May 2013
    Ocean County NJ
    183
    Re: Filling a pool
    Is there a cost savings usually with a water truck as opposed to own tap? I saw a pool water truck on road today and figured must be a discount or why would you use them. Aside from time issue to fill
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Filling a pool
    Depends on where you live. Some places yes, some no.
    Another big driver of trucked in water is what's in the fill water. People with wells that just can't keep up, wells with high iron content, or fill water high in calcium can necesitate trucked in water.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Filling a pool
    Right now, my plan is half and half. Not cheap here, but afraid my well maight pump off. Plus, I havent located better water by truck either.
    Essential Links:
    Mar 2013
    New Hampshire
    351
    Re: Filling a pool
    For me 18k was $600 trucked in or less than $75 with my hose on city water. PB said no brainer use the hose.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Filling a pool
    Just checking to see if you had a flow rate established. Let us know and we'll help you figure it out. 18K won't take too long with something reasonable.
    Essential Links:
    Feb 2012
    Maryland
    400
    Re: Filling a pool
    I used well, took from friday night until sunday afternoon but there were stops in between.
    Basic outline and the times are close but not complete
    Friday @ 8 PM start
    Sat @ 2:00 AM stop
    Sat @ 7:00 AM start
    Sat @ 11:00 AM stop
    Sat @ 2:00 PM start
    Sat @ 8:00 PM stop
    Sun @ 7:00 AM start
    Sun @ 12:00 PM DONE!!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Filling a pool
    At 25 GPM it will be full in 12 hours. You likely have much less than that, but you never know until you measure.
    Essential Links:
