Results 1 to 7 of 7
Thread: BBB levels for a not really closed, closed pool in Dallas
    Jul 2013
    Dallas, TX
    16
    Just finished reading Jason's pool closeing procedure and realized I'm not really closing my pool. Not going to drain it or blow out any lines. The pump and systems stay active all winter and automatically come on if temps get close to freezing.
    My question:
    Do I make any adjustments to the recommended BBB levels for the winter?
    Current levels:
    FC 8
    CC .5
    PH 7.6
    TA 80
    CH 200
    CYA 45
    20k Gal, IG Plaster(I think), DE filter Pentair FNS Plus 48 Sqft, 1 speed pump, cleaner Polaris 3900
    **I don't own this pool, but have been tasked with caring for it**
    Pool is 27+ years old
    38,248
    Re: BBB levels for a not really closed, closed pool in Dalla
    Not really. Just maintain the levels in the recommended ranges. You will just find that the FC lasts a LOT longer.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    You can probably back off to testing once a week too!
    Jul 2013
    Dallas, TX
    16
    I did notice the FC already holding steady much better. Dropped only 1.5 in 7 days.
    Thanks for info guys!
    Aug 2010
    Dallas, TX
    4,052
    I just keep my pool balanced as I do in the swim season. I don't feel guilty if I don't check it but once a week, as they said above the pool stays balanced a lot longer. FC goes down slower, and I can run pump a whole lot less, and since the SWG and pump are running less, my pH doesn't raise as fast. In 2011 when it was so cold here for a long period of time, I had no issues with anything freezing.
    Jul 2013
    Dallas, TX
    16
    Quote Originally Posted by RobbieH
    Good point, didn't think of that. Currently the pump runs 7 hours a day. Which is down from 12-15 hours a day that I had to run it when I was apparently going by Troublesomepool.com standards. What do you recommend for run time? And does it even need to run every day?
    Aug 2010
    Dallas, TX
    4,052
    Run it enough to keep the pool clear. This will vary from pool to pool. Mine seems to be fine at about 4 hours per day. This year I have to refigure, as I put a new VF pump on.
    I would run it every day just to keep everything mixed up. Besides, my timer won't let me schedule anything but every day.
