Thread: How often to backwash DE filter?
    May 2012
    Flower Mound, TX
    130
    I think this discussion was talked about in 2010. But like to get a new response!
    I have a Hayward 48sf DE filter. PB suggested to backwash every month and clean twice a year. When I cleaned my filter for the first time in Sept.2013, psi gauge indicates 25psi after cleaned. Also when I backwash monthly, it also indicates 25 psi after backwashed. I had this pool now about 9 mo. and every month the psi gauge indicates 27 psi, only 2 psi increase a month.
    (25 psi x 25% = 32 psi) Should I just wait till I see 32 psi before backwash and continue to clean twice a year? I think I'm just wasting money on DE powder... Thanks
    John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: How often to backwash DE filter?
    Yes.
    However, I would take my baseline reading after a teardown and thorough cleaning. You'd be amazed how much stuff stays stuck to the grids. Check the pictures in this thread: extremely-dirty-d-e-filter-help-t60455.html
    38,524
    I agree with Richard. You should figure your baseline pressure after a thorough cleaning: use-and-care-for-de-filters-t4086.html
    And then only backwash when the pressure rises 20-25%. Recharge with about 80% the normal DE amount. And then break it down once a year. Sounds like you are doing more work than you need to.
    That is also higher than usual pressures ... likely due to the very powerful pump and low-to-mid sized filter. It is a good size for your pool volume, but might be a little small for your big pump (at least when running on high).
    May 2012
    Flower Mound, TX
    130
    Thank you for the info.
    After bi-annual cleaning and monthly backwashing, my baseline has been 25psi. Must be the big pump and small filter set up. But thats ok, I like having the extra water circulation. I think i will start backwashing only when gauge indicates past 30psi. Right now its indicating 28psi, only rised 3 psi in 90 days. BTW, the gauge does read 0 when pump is off, also it indicates 8 psi on low speed.
    Thanks, again. Love this website
    John
    38,524
    Wow. 8 psi on low seems really high to me as well. Mine barely registers.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Mine on low reads 2 psi.
    Jeff
