Thread: Can anyone identify this test kit?
    Jan 2012
    Kalgoorlie - Western Australia
    27
    Living in Australia it would appear the options for test kits locally are slim - I emailed tdchlorinators and they no longer have any kits. I have found this one which indicates its a Taylor kit however I cannot find any info on it or its testing capabilities. It retails for a few hundred Aussie dollars.
    http://tinyurl.com/ltxbcz9 (I have had to tinyurl it because the link has a few weird characters that break the link)
    I have also found a place that does test products for singular items only but I am not sure if they are suitable.
    http://www.hannainst.com.au/learn_more/c:HI+3851 for cyanuric acid.
    http://www.hannainst.com.au/learn_more/c:HI+38017 for chlorine.
    If they where ok I could perhaps cobble together a kit.
    Cheers.
    7400 gallon, IG vinyl, .75HP, Cartridge, Zodiac Chlor Perfect chlorinator. Almost finished building :)
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: Can anyone identify this test kit?
    Quote Originally Posted by afljafa
    According to the photos on this site, http://www.swimsafe.us/downloads/AG-Catalog-2008.pdf it looks like TKT 442 is the same as the US version of the K2005C. A good kit that contains almost everything you need. If you can add the FAS/DPD test you're in luck. This test however is the most important one there is however, so unless you can add that......I'd pass. Maybe email them and see if they can special order the K2006.
    Jan 2012
    27
    Thanks for that. I see another thread just a little further down that talks about access to Taylor products from an American online seller. I think I will pursue that option as it might be the cheapest option for getting what is required.
