Thread: Screwy pH readings
    Aug 2010
    Lake Jackson, TX
    130
    Screwy pH readings
    I can't figure out why this is happening. When I test the pH I will get a low reading (today's was 7.0) followed by a retest to verify, because 7 didn't jive with the reading from last time, and I get 8.0. I bought new reagent about a month ago and I have soaked my test tube in bleach to remove some cloudiness.
    I generally test FC/CC first then rinse the tube and do pH. Any ideas?
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Screwy pH readings
    Are you sure your rinsing your test vials good ? If you clean them with bleach and don't rinse them good you could get a skewed PH test. That's why you can't test PH with a FC level of 10 or more. It will read a false high PH with high FC levels.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Screwy pH readings
    Are you using the same vial for both ph and the FC/CC test? Which test kit do you have? What is your FC level?
    Aug 2010
    Lake Jackson, TX
    130
    [Are you sure your rinsing your test vials good ? If you clean them with bleach and don't rinse them good you could get a skewed PH test. That's why you can't test PH with a FC level of 10 or more. It will read a false high PH with high FC levels.]
    I have only cleaned the vial with bleach once about 2 months ago.
    [Are you using the same vial for both ph and the FC/CC test? Which test kit do you have? What is your FC level?]
    Yes. I usually test FC first then rinse with pool water once and then check pH. My FC was 1.5/0 (low, I had closed the pool a few days before) when I last got the weird readings. I have the Taylor K2006 kit.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I forgot that the taylor uses one vial for both tests...I wish they wouldn't do that. If you are rinsing well, then I don't know why the ph difference. Do you have a separate ph kit that you can check it with?
    Aug 2010
    Lake Jackson, TX
    130
    Thanks for the input. I'll be sure to rinse better next time and see how it does.
