Results 1 to 9 of 9
Thread: Pump not working... Making humming noise.
    Help! Our pump is not working. It makes a humming noise when we turn it on. So we replaced the capacitor and that did not solve the problem. Any ideas on what else it could be? Attach is a picture if it helps in any way.
    35,000 gallon inground pool
    D.E. Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump not working... Making humming noise.
    Does the shaft spin freely? Usually you can take of the end cap and try spinning the shaft from there (with power turned off to the pump).
    I dont think my husband tried that... I will tell him too. Would that be an easy fix?
    D.E. Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If it doesn't spin freely it may indicate either something is jamming the impeller, which should be an easy fix or bearings that need replacing which is a little more work.
    Ok i will tell him to check that out and see what it is...
    D.E. Filter
    Smykowski's Avatar
    Sep 2011
    3,065
    If the shaft spins freely, the humming likely points to a bad start capacitor. Very cheap and easy fix if that's the case.
    Can you post a picture of the whole pump from above?
    Jan 2011
    Richmond, Texas
    595
    Quote Originally Posted by luria8
    Sounds just like my pump i had to replace. Turn it on and it would hum. I had to replace it. To just replace the motor was like 50 bucks cheaper than replacing the entire thing. So i just replaced everything.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    It could also be a faulty capacitor. I've been through several in my short time as a pool owner.. I would try a couple before you rule that out.
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Thanks for all the help!!! You saved me some $$$!!! It was a bad bearing that needed to be replaced! That solved my issue! Now i have another issue with DE getting back into the pool! Not complaining though, i love my pool!!
    D.E. Filter
