Results 1 to 9 of 9
Thread: Loud noise coming from Booster Pump
    Jul 2013
    Carrollton, TX
    40
    For the last couple days there has been a loud screeching sound coming from my booster pump. There is also water outside the motor housing. any idea what is causing this and what the solution is. I have no idea how old the pump is as I bought the house this summer. Here are a couple pics for reference.
    14,000 gal IG + spa, DE Filter, 400k BTU heater, Polaris 280, Aqualink RS6, TF-100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Loud noise coming from Booster Pump
    The screeching is likely bad bearings. The water is likely a bad shaft seal. It's hard to see in the pictures....can you tell exactly where the water is coming from?
    Jul 2013
    Carrollton, TX
    40
    The water looks to be coming from the seal. You can see the water through the hole to the right of the motor. Is it possible to replace the bearings and seal?
    Smykowski's Avatar
    Sep 2011
    3,065
    Definitely. Search the forum, there's lots of info on shaft seal replacement. You can look on youtube for bearing replacement.
    Jul 2013
    Carrollton, TX
    40
    What's the best way to find the exact parts I need? Google is only showing the entire motor.
    Smykowski's Avatar
    Sep 2011
    3,065
    Whats the model number of the pump?
    Jul 2013
    Carrollton, TX
    40
    I've decided to replace the entire pump as it is 11 years old. Thanks for your help Smykowski.
    Oct 2013
    29
    good call jww, that is your best bet!
    Smykowski's Avatar
    Sep 2011
    3,065
    You're welcome. If you're at all mechanically inclined, dont pitch the old pump; replace the bearings, and you'll have a spare pump for emergencies.
