Results 1 to 12 of 12
Thread: What to do / Where to eat near DFW?
    38,295
    We have a plethora of members from the DFW area ... so maybe someone will be able to offer suggestions.
    Lets say one was going to be in Ft. Worth after about 2:30PM and have 3-4 hours to kill before a 7:40PM flight out of DFW.
    Any quick/cheapish place I should grab lunch on the way from DFW to Ft. Worth?
    What is something that is a must-see/do in the afternoon?
    Any place near/in the airport I should definitely grab dinner?
    Thanks
    Re: What to do / Where to eat near DFW?
    I don't know that area, and I can't believe I retained this info, but I recall a "Best Thing I Ever Ate" show on FoodTV that had Duff the cake guy who said the best thing he ever ate was at Lonesome Dove (or close to this name) in Fort Worth. Called it a Tomahawk Chop and it looked amazing.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    okay, never mind. I googled it and it looks like it is well over $100 to try this dish. Good luck, wish I knew the area and could point you somewhere.
    38,295
    Wow. That may be a bit over my price range. Although, you reminded me that I should check out where Guy may have eaten on Diners, Drive ins, and Dives.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I would recommend to try The Stockyards. It's a great place and you probably won't want to leave!
    It's historic area full of cafes, restaurants a museum of the history of Ft. Worth and all sorts of stuff. Very interesting to just walk around the place and window shop or actually buy something.
    Burger and bar b que places are tasty enough. I wouldn't say it was exactly cheap with burgers and fries for about 15.00. Several pricey steakhouses are there too and some of them offer a reasonable lunch menu till 3 PM
    In any case though, it's a great place to kill a few hours.
    http://www.fortworthstockyards.org/Index.aspx
    Divin Dave,
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,387
    Chef Point Cafe. I've never been there but I have heard it is very good. Looks like it's not too far from the airport. However if you are looking for fast food just hit the nearest Whataburger!
    Love TFP? Become a
    TFP Supporter!
    I would recommend going to Billy Bobs. I have lived in Texas all my life and only recently went there and had a blast. Get a picture of yourself on the big stuffed bull.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Not quite as familiar with Ft. Worth as I am with areas east of DFW Airport, but I have received several good reports on Cattlemens Steak House from some Ft.Worth-area residents. It's located in the Ft. Worth Stockyards.
    Apr 2010
    Buckeye, AZ 85326
    619
    I was a road warroir for a long time and in and out of that area from 1997ish thru the early 2000's. I always made it a point to stop at a place called Razoo's Cajon Cafe. It was always a very light hearted atmosphere and what I would consider descent food for your buck and GREAT service. Granted its been a long long time since Ive been there and my tastes were a bit different back then but I would not hesitate to go back.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Be careful with your time and trip. It will be real easy to burn up 4 hours running around the Metroplex. Traffic can be less than forgiving.
    Essential Links:
    Nov 2013
    Texas
    13
    Brushpup is correct about traffic. A lot of construction right now but if you take 121 from downtown Ft Worth to the north side entrance you should miss much of it as the north side is mostly completed compared to the south entrance.
    The Stockyards is a good suggestion and if you like Mexican food then just south of the stockyards there are several very good places to go. If BBQ, Coopers now has a place on the north side of the stockyards. H3 steakhouse isn't bad either. Cattlemens overpriced.
    Downtown Ft Worth is full of restaurants.
    For dinner there are so many restaurants around the airport you can find anything you desire at the time. Good luck.
    IG, Pebblesheen, 17K capacity
    Intelliflow 2hp VS pump, 30" sand w/zeolite
    Paramount infloor system
    Spillover Spa, Twirly Birds, Deck jets
    Built November 2013, Abilene Texas area
    Aug 2010
    Dallas, TX
    4,052
    I'm a big fan of Razoo's, and the original one is in Sundance Square in Downtown Ft. Worth. If you want to spend more, the Reata is around the corner, VERY good.
