Results 1 to 10 of 10
Thread: My heater is cracked by freeze. What should I do now?
    Jul 2012
    Austin, TX
    75
    Hi all,
    I recently re-plumbed my pool that had set empty for 2 years. When I started to let water go through the system, water dripped out from a hairline crack at the heater manifold where the 2" pipes connect. I am very certain that the crack was caused by a hard freeze sometime ago because my above ground pipe and valve also cracked.
    A new heater is about $2000 and the part is about $300. If this is the only part I need to change, I will replace it. However, I just don't know if other components may also be damaged by the freeze or sitting idle for so long. Does anyone have any experience on heaters damaged by freeze?
    Scott
    Lazy-L shaped pool and a spa. 22.5k gallons. Pentair VS pump. Pentair cartridge filter CCP520. STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Pebble sheen (blue granite) Wooden deck.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: My heater is cracked by freeze. What should I do now?
    The water goes through the manifold into the heat exchanger then returns so those are the only places you will find a water leak. If the leak is not bad I would turn it on check to see if it works then estimate the cost for repairs.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    What brand/model heater?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2012
    Austin, TX
    75
    It is in my signature. I think the material is some sort of fiberglass, so I am going to take it apart and patch it with West End epoxy from the inside. Hopefully it should fix the crack.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    You can try to repair/replace the part that is broken and then pressure test the heater to see if any more leaks exist
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2012
    Austin, TX
    75
    How do you pressure test a gas tester? Is it something I can do myself?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Not easily, you have to plumb up a pressure gauge with the ability to send water from a garden hose into the system. they sell one at leaktools.com to give you an idea.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    You can test it pretty easily with some pvc pipe and fittings. You will need to cap the outlet then connect a 90 on the inlet with a length of pipe sticking straight up and a threaded cap. Install a Schrader valve (for adding air) on the cap, fill the unit with water leaving about a foot of air in the line, thread on the cap and pressurize it with a bicycle pump. If the pressure holds, you're good.
    The only tricky part will be getting the unions to connect to the heater.
    Here's a better price on the parts: http://www.radishandlettuce.com/Pentair ... 7Aodmx0Aiw
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by scott_home
    Sorry about that I usually don't read too many signatures.
    As others have said you can try and epoxy it but many times it doesn't work for any decent period of time. The worst thing is if the heat exchanger is damaged you may not know right away. If it has a slow leak it could a long time for the can to fill with water before it finally stops working.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Remove a manifold flange bolt on the heater. Remove the lowest bolt (closest to the ground), if water begins to come out, you need a new heat exchanger. Unless of course the manifold is the part that is cracked, that is relatively easy to replace. Can you physically see where the water is leaking from? Or is it coming from somewhere you cannot see, like from under the heater?
    Factory Warranty Station for:
