Results 1 to 9 of 9
Thread: Going to freeze tomorrow
    Fort Worth, TX
    83
    I keep my bleach and acid in a corner of my patio.
    It's supposed to get down to the mid 20s tomorrow night.
    Should I bring them in the house?
    If that temperature won't hurt them, I'd rather leave them where they are.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Going to freeze tomorrow
    It's not going to hurt them, no worries.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    ^ What he said.
    Rest easy...Temps would have to get down to around 14F or so before you would have to worry about 8.25% bleach freezing. As for the acid, the freezing point of full-strength 31.45% MA is around -50F, so virtually anyone in the contiguous 48 states would have no worries about the acid freezing. Even half-strength acid (~ 15%) would not freeze unless temps dipped just below 0F.
    Fort Worth, TX
    83
    Thanks, guys.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    What about pool equipment for a light freeze like this? Just let the freeze sensor do it's thing or run out and turn the pumps off?
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    38,301
    You want the pump ON if the temperature is below freezing. Whether you trust a freeze sensor (if you even have one) or just manually turn your pump on is up to you.
    It is so rare here, that I just turn the pump on over night ... that was before I had automation, so I might see how the freeze protect works.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Got it-- hit the switch before bed tonight. Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you don't have a freeze timer, contact a pool service about installing one. What if you were gone tonight?
    Essential Links:
    38,301
    Well, as Mark says in the other thread it takes over 8 hours for a 2" pipe to freeze, so he does not even bother with freeze protection:
    question-about-keeping-pool-open-t71610.html#p595117
