Results 1 to 20 of 20
Thread: Worried about pool light with snow here
    Hi,
    Literally poured my last concrete on Friday to finish an ungodly diy inground pool install. Have a Hayward prologic light in the pool. I live in a suburb of Toledo, oh. So, from all I have read and been told, there should be water in the conduit coming from the light. This just does not make sense to me, especially since it's under concrete now. and the light is in 2.5 feet of water after draining below my skimmer. Will the water freeze in the bucket? Just can't wrap my head around this issue.
    Any experience, helpful!!!
    Rod
    38,290
    Re: Worried about pool light with snow here
    I am confused about what you are asking. What bucket?
    Yes it is normal for water to be in the conduit between the light fixture and the deck box. Whether the water will freeze that deep depends on your weather.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    That's one thing I certainly never thought about, when it comes to winterizing.
    I think he's talking about the light niche by the way (bucket).
    So when a pool is winterized, nothing is done to the water in that conduit...so don't you run a risk of it bursting from ice?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    The light niche is called a bucket I thought... Sorry for the confusion. my pool had to be raised 20 inches due to ground water. the conduit comes out of the retaining wall and then up to the junction box.
    I wanted to put some jb weld/potting compound over the hole in the niche where the wire exits. It got to cold and didn't get it done. that way antifreeze could be dumped in the conduit. Read of some doing it. But I'm wondering how far down the water freezes in the actual pool as now the light is only in 2-2.5 feet. I'll send some pictures and maybe it will be clearer...
    Rod
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I'll be curious what folks say here. My pool is done (no patio, but the pool is all done) and winterized. But no attention was paid to the light conduit...hmmm
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,089
    I'm just a bit down the road from you in Steubenville Ohio. Winters are about the same (you get more lake effect snow). In the 20 years with our pool not once have we had a problem. It's not a spot to worry about as the water has room to expand IF it freezes. With our temps, I highly doubt it will freeze that far down.
    Here are some pictures. The first is of the light. It is 3 1/2 feet of water. I took the level of the pool down 4 inches below skimmer. The actual pool water will freeze at the level of the light, I assume. That means water in the niche also. Maybe this isn't a big deal, but if it cracks, it will be a bad day..... The others show the conduit coming out of the retaining wall..[attachment=2:2h744cqo]small1.jpg[/attachment:2h744cqo][attachment=1:2h744cqo]small2.jpg[/attachment:2h744cqo][attachment=0:2h744cqo]small3.jpg[/attachment:2h744cqo]
    30,421
    In a nutshell, you are overworrying about the water freezing in that conduit....disregard it.
    Quote Originally Posted by rstandi
    Rod
    DO NOT put JB weld in the conduit! If you ever need to replace the light you will be in trouble. If the water can freeze in the light niche you may want to consider removing the light for the winter. It's not a big deal. My water level was about at the top of my light last year and it froze and cracked the seal on the light (that or I had a colorlogic that the seal went bad in after only 3 years).
    18' x 36' saltwater inground vinyl pool
    Nov 2011
    Moberly,MO
    1,010
    rstandi most generally I would agree that you are worried about that conduit for no reason. But with the way your conduit is exposed that is a possibility. Pull the light from the niche. pour rv antifreeze into the conduit and you should be okay. better to be safe than digging up to repair
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    But for those with fully installed lights, why do you not have to worry about the water freezing and cracking the conduit?
    May 2013
    North East Ohio
    959
    Quote Originally Posted by steveg_nh
    I have the same question...in fact my LIGHT MFG says I need to completely remove my light, etc. Yet by PB told me not to worry.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Quote Originally Posted by toofast
    Really? That would stink every year! I didn't read that on mine, but maybe it's there. I have a Hayward ColorLogic 4.0 light in a PentAir quickniche.
    I don't think it's a matter of the water freezing the conduit. It is a matter, depending on the water level, of water freezing and damaging the light itself.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Cause the niche is filled with water to? Why do they do this, vs a dry niche? Never understood that.
    May 2013
    North East Ohio
    959
    I have a Fusion G4 RGB LED - (think someone bought them though) cause their web site is dead.
    Jul 2011
    Eastern Ohio
    7,089
    They suggest this to avoid all damage to the light itself......not the niche or conduit. IF ice were to freeze as deep as the light it COULD cause pressure to crack the light itself. The water would have to freeze into a very thick piece of ice however for this to happen. The majority of the time it only freezes maybe a foot deep at best in Ohio. Maybe in area's with harsher winters it could be a problem, but around here I've yet to have an issue. This year is the first time ever I've worried about ours, as the water level is even with the light due to a leak and us replacing the liner next year. If our water freezes at all it's against the light....but simply removing the light will avoid this problem.
    As for the niche itself.....the way they're kinda built allows for the ice to expand if it needs to. Highly doubtful the PVC would completely fill with water and freeze......but as swimcmp suggested if you're really worried add some antifreeze to stay on the safe side. Do NOT use JB weld however.....as if you ever need to remove the light you'll be cussing up a storm.
    Wouldn't the antifreeze just go directly into the pool water without plugging the hole where the wire exits the niche?
  20. Back To Top    #20
    Mar 2015
    Iowa
    34
    I have the same problem. I just back filled my DIY pool 2/3 and the pool is full and it just dawned on me that I ran my conduit horizontally along the pool wall with the plumbing at 30"ramping up to ground level. This exposes about 60 feet of water filled conduit to freezing. Has anyone ever successfully blown out a light line and found a plug that would seal around the light cord and into the conduit hole in the niche or should I dig the up and bring the conduit straight up to the surface then to the transformer so when the water freezes it can expand upward?
    18x36 48" steel panel in ground pool with 27 mil vinyl liner. Hayward Tri-Star 2 speed 1 1/2 pump, Hayward C12002 cartridge filter, Hayward 350BTU NG heater, 2 Hayward Color Logic Lights.
