Thread: CYA
    New Brunswick Canada
    819
    CYA
    Ok, so we all know that high CYA is the major cause of issues in pools, chemical manufacturers can make ever other useless product under the sun, but why cant they make a product that will deplete CYA?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA
    There has been one, but the cost is excessive.
    819
    Re: CYA
    what is it? It might be more cost effective then ppl having to drain their pools, especially if they are on a well system, some wells cant handle that much water draw
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,093
    Re: CYA
    The product was almost an "oasis" (was even marketed under the o-ACE-sis label) as I don't remember anybody ever buying the product, just a few people seeing it at Ace Hardware stores.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CYA
    It's not just expensive, the the product was melamine, just like what you use in the CYA measurement test. It creates a cloudy, precipitated mess and if you add any more CYA to the water it will cloud back up again.
