Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: New pool woes...
    Nov 2013
    Bathurst, Australia
    19
    New pool woes...
    Hi guys,
    I'm an Aussie who has just bought a property and this is my first pool. I grew up swimming in farm dams so this is a bit of a change for me!
    My first mistake was to not get the pool equipment checked prior to our purchase.
    The pool is salt water and about 30 000L and we are on 30ac and the pool is surrounded by bushland. We are heading into the summer months down here.
    The pump and filter are both fine (am running them on a simple timer at the moment), though the controller unit is causing me grief. More often than not it will come up with a "no flow" error and shut down.
    The local pool guy says the unit is faulty and has quoted for a new chlorinator etc. This is $1500 we don't have at the moment, and I am wondering if there are any other options available to me?
    I work from home and have heaps of spare time, so that isn't an issue, and I am happy to put in effort rather than $$
    Any help or advice would be great.
    Mark
    10K gal, IG, Fibreglass, 1.5hp Onga Pantera,
    22,544
    Re: New pool woes...
    Welcome to TFP.
    What brand and model is the swg?
    Most of the time when you get flow errors it's either the actual flow or something wrong with the flow switch.
    38,267
    Welcome to TFP!!!
    If the SWG turns out to not be an easy cheap fix, given that you have heaps of free time, if you are willing to use 5-10 minutes of that time each day on the pool, you could just maintain the proper chlorine levels using liquid chlorine.
    Since you are new to pools, likely a good idea to start reading Pool School and these will be good at first:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    One issue you are going to run into is source a good enough test kit down there. We have a few members down there currently active that seem to find the cheapest way to get a kit to be buying it in the US and having someone shipping it down to you. Rather than ordering a kit from a local company. These are what you want to be looking for: Recommended Test Kits
    Nov 2013
    Bathurst, Australia
    19
    Welcome to TFP.
    Wow, you guys rock!
    Looks like I have some serious learning to do!
    It is a Zodiac the same as this http://zodiac.com.au/products/chlorinat ... -generator
    The pump is on at the moment but the pressure isn't what it was this morning. The leaf filter is clear, spray out the big filter?
    EDIT: I have emailed a local source about the FT-100 Fingers crossed they have some in stock!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, rooni79
    We love having you southern hemi folks on here...keeps it more lively when we have winter in the USA.
    What was and is the filter pressure gauge indicating? When you turn the pump off does the gauge go to 0?
    Nov 2013
    Bathurst, Australia
    19
    Hi Linen,
    The pump gauge was indicating 150kpa and dropped to 0 as soon as I shut it down
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Is that the "clean filter" pressure? What were the pressures you mentioned in your previous post?
    By the way the test kit is a tf-100 (not ft-100) and is difficult to get in Aussie land. Here are some posts on the subject: http://www.troublefreepool.com/taylo...ia-t71032.html...and http://www.troublefreepool.com/fas-d...ilit=australia
    Nov 2013
    Bathurst, Australia
    19
    Quote Originally Posted by linen
    Those are the "dirty filter" pressure readings.
    Quote Originally Posted by rooni79
    That's about 22 psi, which is too high for most clean filters. It could be the cause of the no-flow error.
    What pump and filter do you have?
    Support the site
    Nov 2013
    Bathurst, Australia
    19
    ok so the pump is a Pantera by Onga (1.5 hp, 2800 rpm ), and the filter housing "thingo" is a davey easy clear 1500.
    I used the hose to spray out the filter, which was choked with a whitish chalky substance. The pump is now sitting on about 115 kpa and water pressure through the jets is greatly improved. Looks like I will clean out the filter every few hours till it gets a little cleaner. Would you recommend a new filter, or wait and see??
    I'm overwhelmed with all the help so far, simply amazing!! Free beer at my place if you are ever in the neighbourhood
    22,544
    If your filter is clogging that quickly then you surely have an algae bloom.
    What does the water look like?
    Nov 2013
    Bathurst, Australia
    19
    When we moved in a week ago, the water was a lovely green. The pool guy dosed it with liquid chlorine to kill it. The water isn't green anymore though it is a slightly murky milky colour if that makes sense.
    38,267
    Likely not everything is dead. Ideally you should follow the SLAM process described in Pool School, but difficult without the FAS-DPD chlorine test.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Even if it is all "dead", it likely hasn't all filtered out. Backwash-circulate--repeat (if necessary).
    I'm thinking that once you get the water clear, and have a clean filter, your chlorinator will probably stop giving the low flow error. I think that it's too early to conclude the chlorinator is faulty.
    In addition to algae, you might be having issues with calcium scale. If you can provide a full list of chemistry values, we could try to assess to likelihood of scale being a contributing factor to the filter getting clogged.
    You might need to clean the filter element with a degreaser and/or descaler if just a hose is not sufficient. You might have to replace the filter element if it is too deteriorated to be useful. Here is a link to filter cleaning instructions
    http://www.unicelfilters.com/retailers/ ... _users.asp
    Support the site
    Nov 2013
    Bathurst, Australia
    19
    Quote Originally Posted by JamesW
    This is exactly what I have been thinking too. I think old mate pool man is too bloody keen to sell me some new components!! I will keep at it and see how we go
    Oct 2013
    Adelaide, Australia
    77
    hi rooni79
    I'm in Adelaide and embarking on this pool owner voyage of discovery as well.
    I've had a test kit mailed from the USA (K2006-C from Amazon.com mailed to family acting as freight forwarders), (still waiting on its arrival, USPS tracking information for "Priority" parcels sucks so I've no idea where it is either) I'm hoping it's got through customs etc. OK and it's just poor tracking, rather than a lost or destroyed parcel!
    [Edit: (2hrs later) Tracking info has appeared apparently it's in AUSTRALIA. No more details that that, but at least it's going to make it... I say that, it still has to survive AusPost in Adelaide, which is bl00dy awful!]
    For when you do get to SLAMing, Bunning's do Liquid Chlorine.
    The Bathurst Bunning's does a 15L swap canister for $10 returnable deposit and $10 a fill (lucky you... I can't get that in SA!) which is only about USD0.22 per US floz, which is pretty good I think judging by the US prices posted on here.... which makes a pleasant change in Australia!
    Steven
    18.5k US gallon/69kl IG tiled with an Onga Pantera 25" sand filter, powered by a Davey Silensor 200 1HP/0.75kW pump coupled to a Zodiac TRi (mid) SWG K-2006C Test kit imported from the USA...
    in Adelaide, Australia...
    I would also recommend checking the cell for scale or debris.
    Support the site
    Nov 2013
    Bathurst, Australia
    19
    Hi Steven
    Good to know about the Bunnings Chlorine caper mate! Though I hate giving money to those buggers
    I ordered the test kit through poolvacparts. Hopefully it won't be too long.
    Now a bit of an update....
    So I gave the filter a very thorough clean with the hose, and I then soaked it in detergent and napysan for about 4hrs. I gave it another good hose out and reinstalled it. I fired her up and it sat on about 60kpa, which is awesome. I then hooked back up the Zodiac and it is still running without an issue two hrs on!
    I may have enjoyed more than one beer this evening after scrubbing and vacuuming the pool
  20. Back To Top    #20
    Oct 2013
    Adelaide, Australia
    77
    Yeah Bunnings is a necessary evil for this pool lark, especially if you're trying to keep costs down, they are much cheaper than the pool shops. Pool shops are even less deserving of your cash though! We have BioGuard branded pool stores here and they are hellishly expensive for the basic chemicals (had no idea my first year and it cost me a [s:1rauvmgr]small[/s:1rauvmgr] fortune buying bicarbonate for $25 a kilo!
    Steven
