- May 3, 2007
- 16,895
- Plaster
- Hayward Aqua Rite (T-15)
Yes, you can downsize the impeller. You can buy one online or through your PB. Your SWG should not be an issue. I have a 1/2 HP two speed pump and my SWG works fine on low speed. The heat pump is a different issue and may or may not work on low speed. It depends on the requirements of the heat pump.
However, a 3/4 HP impeller will probably give you 93 GPM on high and 46 GPM on low which should be fine for your heater.
