Results 1 to 9 of 9
Thread: Swimpure 20 replacement T-cell
    I have a Swimpure 20 with r1.40 with T-cell-5 that was installed in 2009. For the past few weeks the salt levels have been displayed incorrectly and it shows very low level and since no chlorine was produced I had algae; I have been resetting the salt level by going off - auto and then based on the reading from Pool Medic place I then go to super - auto to set the level; I went to pool medic and they tested the T-cell and it has officially failed; I called Hayward for advise on replacement cell and the technician who was "newbee" advised I need to replace this with T-cell-5 which is a hard part to get; I went to pinch-a-penny website and they say I can use either T-cell-5 or 15. Need guidance as I have read in the forum that if Tcell15 is used its current draw could blow the circuit board. Appreciate the guidance.
    http://store.pinchapenny.com/product/ha ... anty?s=204
    I have photos of the panel and the serial number if that is required.
    38,262
    Re: Swimpure 20 replacement T-cell
    Welcome to TFP!!!
    How big is your pool? I am pretty sure your system will work with either the T-5 or the T-15. I would likely get the T-15 as the cell should last longer.
    Where did you read that the larger Cell would blow the circuit board?
    Mar 2010
    122
    You can def use a t-15 on this system. You juts have to switch the cell type on the board itself. go unitll you see the T-5 then simply go to super chlorinate and back down to auto and it will change every time you do this. keep repeating until you get to t-15. The same boards are used for all of the swimpure, haywards just different settings between diff cells. I know this cause I am a certified warranty center for Hayward.
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    Guys, thank you and apologize for the delay in response as I was traveling. I opened the front panel and this is an old Motherboard from Goldline control PN#G1-066012C-1 Rev C and the software version is R1.40. This version of hardware has an option on the motherboard to either select T-5 or T-15(need to solder the 2 points). It seems this is the only option. Appreciate the guidance.
    There is a jumper that goes over the pins for the t-15. It might have been left in the power box somewhere.
    Support the site
    James, PCB does not show the jumper, all I see the square block showing TC5 - no jumper (blank rectangle) and TC15 - with jumper (solid white rectangle); based on the explanation I believe I need to solder couple of standoffs and a jumper if I can find them or I will solder a wire across the 2 points.; hope this is OK
    Can you post a picture of the board?
    Support the site
    I took the photo at an angle and have marked it with a circle; I see the jumper for Master/Slave and underneath that you will see the one on the motherboard for T-5/T-15. Appreciate the confirmation so that I can purchase the T-15 rather then T-5 which is what was installed which is smaller for my pool; I had to have it running at 70+ percent since day 1.
    I can't see the pins. I'm not sure if you can solder the points or not.
    Support the site
