Thread: SR400LP "E13" Error Code?
    Hello my unit is displaying "E13", then it turn off. Does anyone know what this error code means?
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: SR400LP "E13" Error Code?
    Error codes are E(Zero) something. If you are handy, power off unit, remove the four screws holding the plastic sides on, and then there are two retainer clips holding the dome top on, remove them. Now remove the dome and flip it over. Once you have it flipped over, power up the unit and then you should see some LEDs lite up. Does anyone of them stay lit?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
