Thread: sand in pool
    sand in pool
    hi, i have sand on the bottom of my pool. I thought it might be due to backwashing, it's not. I vacuumed the sand with a wet vac, the sand has slowly returned and slowly buliding up. I brush away the sand, it moves once settled. It's a hayward sand filter s244t.
    I am running it with a 1hp hayward super ii pump.
    I'm considering not calling a pool tech and just replacing it with a new one.
    pool tech to tell me whats wrong with it 80 dollars
    pool tech to return second time 80 dollars
    pool tech to install new laterals with centre pipe 100 dollars
    pool tech will need to change sand if changing lats 200 dollars
    new filter (same one), delivered 450 dollars
    change the sand over myself
    total 650
    not sure what to do, if problem returns would be very disappointed.
    i've considered changing the laterals and sand myself, would be looking at close to 300 tops for this.
    please advise, just don't want to waste the little money i do have and not fix this problem.
    another option is to just leave it the way it is for as long as possible.
    thankyou.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: sand in pool
    Hi, welcome to TFP! To make sure it is sand and lot dead algae, turn on the pump, hold a clean, white sock over the return. If it is sand you will collect some in the sock. Once you are sure it is sand and not dead algae, you could save a lot of time and money fixing the problem yourself. Here are a few items on the filter to check. Check that the spider gasket in the multi- port valve is in good condition and seated well. Make sure the center pipe is well seated, no chips or cracks. Check the laterals for cracks. Be very careful checking the center pipe and laterals, they can be easily broken.
    Love TFP? Become a
    TFP Supporter!
    22,553
    Re: sand in pool
    Once you hold or tie the sock over the return, as Zea said, if it's sand, I definitely recommend repairing it yourself.
    Re: sand in pool
    thankyou for all the suggestions, much appreciated.
