Results 1 to 10 of 10
Thread: Solar water heating
    Sep 2013
    San Diego, California
    21
    Solar water heating
    Guys - I'd appreciate a bit of guidance on my heating system. The pool water circulates to the roof where it's heated in those black panels. The system is about 9 years old and it's been very effective. Just recently however we've begun to hear water dripping and gurgling constantly while the system is off. Is this a problem? Any idea what it might be?
    Thanks
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    5) Flow rate of filter; 120
    Location - San Diego, California
    38,284
    Re: Solar water heating
    The panels are designed to drain when the pump is off. There is a vacuum release valve that allows air in and the system to drain. Some noise is not uncommon, although odd that it just started. Wonder if maybe the vrv is not allowing the system to drain as easily as before and thus more noise?
    Sep 2013
    21
    Yes it definitely just started doing this. Any idea where this valve is likely to be or what it looks like?
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    38,284
    Often the vrv is at the very highest point, but that is not always true. They look like a short pipe that screws in and has some holes at the top.
    I am not sure how you could tell if there is a problem with it. Also not really sure there is a problem. Both my houses with solar have made noise when draining.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Here are a few pictures. These can usually be seen fairly easy:
    However, this type goes in the end of the panel header and can't be seen very easily from the ground:
    Mark
    Surf Hawk's Avatar
    Sep 2013
    Santa Barbara, CA
    114
    Hi, I am a newbie too, but does your system make a gurgling, trickling sound when it is on also? I discovered our solar system makes a lot of funny noises when the filter pressure rises. When I backflush, all noises go away. I attribute it to lower flow from higher pressure but maybe I'm wrong. Since this happens even when it is off, this probably isn't your problem.
    22,000 gallon IG; plaster; 16x32 Rectangular, Depth 3.5-8Ft.
    Hayward Pro-Grid DE Filter - 48sqft w/ cellulose fiber & Hayward Energy Flo RS Pump - .75HP (1.85SF)
    Very old 312sqft solar system, TFT-100 Kit with Speedstir
    38,284
    If the filter is dirty, that will reduce the flow and pressure to the panels. If the pressure is too low at the vrv, then it may not close and could be gurgling and pulling in air.
    Sep 2013
    21
    Thanks guys, I really appreciate the help. On closer inspection it appears the noise isn't water dropping form high levels, it's air bubbles percolating up through the system. I guess I have a leak somewhere. I'm going to give the filter a good clean and inspect everything. I'll report back
    Thanks
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you are getting air in the system, it will be on the suction side (before the pump impeller). Common causes are, low pool volume or stuck skimmer weir causing air to be sucked in at skimmer, leaking pump basket gasket, leaking pump drain plug, leaking suction side valves/fittings. See this pool school article for help on leaks: http://www.troublefreepool.com/pool-...leak_detection
    Sep 2013
    21
    Re: Solar water heating (SOLVED)
    It appears that my filter wasn't working properly. A few of the grids were broken and it needed a good clean. So now the pressure is good and the gurgling noises have disappeared. Thanks everyone
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
