Results 1 to 12 of 12
Thread: Advice on installing pump
    Hello Everybody,
    I am working on a pool; the pump is not working -- when I start this it does some noise and then nothing happens. So I stooped the pool. I am assuming the motor/pump needs replacement.
    Can anybody please advise on
    1. Should I replace only the motor or the whole thing (the pump and the motor)?
    2. its an AO Smith 1.5 HP motor and Hayward Super II pump. Can I get the exact models (it's an old pool though!)? If not then which model do you suggest and also that will need some extra plumbing work, right?
    Thanks in advance for your advice.
    NUbee!
    Rancho Santa Margarita, CA
    Gallons? Unknown. Medium sized pool.
    Filter? I think cartidge. Big beer can looking device with pressure valve on top running around 30 PSI
    Inground plaster pool.
    Spa above spills into pool. Waterslide above Spa spills into pool.
    Heater: Purex Triton MiniMax
    Vacuum: Hayward Navigator
    Pool guy does regular water maintenance.
    22,542
    Re: Advice on installing pump
    It could be the capacitor. If it hums but doesn't start and you can turn the shaft by hand, it's probably the capacitor.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Thanks Dave for your quick answer. I will look into the capacitor. Can you please advise my questions (#1 and # 2 above) in case I need to replace the pump?
    NUbee!
    22,542
    If it is the motor I would go with replacing it with a 2-speed motor. That way there's no plumbing to change and it will save a good bit of electricity cost.
    Thanks again Dave. Any recommended brand for the 2 speed motor? Also in that case do I only change the motor or the motor + pump?
    NUbee!
    22,542
    Just change the motor. The brand really doesn't matter, just match the frame, voltage, hp & service factor to the high speed.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you post the model number of the motor (and also the pump if you can find it), we can give you some suggestions.
    I don't have the p/n handy. However this is an AO Smith 1.5 HP Circular fleng motor and Hayward Super II pump. Does this help? Thank you.
    NUbee!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It does if you know if the 1.5 hp is full-rated or up-rated. Do you know?
    I don't know that. What is full rated or uprated?
    NUbee!
    Never mind, I got the part # for the motor: 7-184982-23; Century Centurion. Hope this helps.
    Thanks in advance for your kind help!
    NUbee!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is a 1 hp full-rated motor. Do you know if it has 115 or 230 volts supplied to it?
