Results 1 to 9 of 9
Thread: Plumbing depth question
    Aug 2013
    Maryland
    93
    Currently working on an Owner/Builder pool in Maryland. Plumbing it out right now.
    How deep do I really need to run the plumbing back to the pad? I was currently just going to go about 8-12", enough room for pavers + base. Is that acceptable?
    Frost line is 30+" here, and I can't really imagine trenching 3 feet down. I will be blowing out all pipes in winter.
    22,543
    Re: Plumbing depth question
    If you have to meet code there and pass inspections, you'll most likely have to bury them below frost line. Your local AHJ will be the best people to ask.
    Aug 2011
    Cochranville, PA
    228
    Take the extra time and go below the frost line. You'll be glad you did. I did a paver side walk. It was small and gets little use. I went down 2 ft and after one year it had settled and was very uneven. As far as the plumbing...They make codes for a reason. And the reason is people like me who tried and cut corners and am paying for it now. Imagine something comes up and you can't get to blowing out the pipes. You'll spend more time repairing everything.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Aug 2013
    Maryland
    93
    Only inspections required here are for electrical and for final use (once everything has been completed).
    Aug 2013
    Maryland
    93
    Where do I even find the code regarding this? The only thing I have found from my local office with regards to pool codes are fencing and bonding requirements. That's about all.
    22,543
    If they don't do a plumbing inspection, you can do what you want, but as Raid said you should go below the frost line. That ensures that if when you blow the lines out and you don't quite get it completely dry, it won't freeze and burst.
    New Brunswick Canada
    819
    Proper winterizing can ensure zero problems, I am way north of you and its very rare for lines to be buried over 8", our frost goes as deep as 50"
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    <Where do I even find the code regarding this? The only thing I have found from my local office with regards to pool codes are fencing and bonding><<requirements. That's about all.>
    Plumbing code is where will probably need to look. Or you can go to the building permit office and get info about it.
    Codes vary from town to town. Depending on your town you may not have to have one. Where I live at, there isn't a plumbing inspection required as long as you don't tap into the city water supply or sewer.
    Divin Dave,
    Feb 2012
    Maryland
    400
    Im in MD, my pipes are for the most part 30" below, however my pad is below the level of the pool so where the pipes come out under a retaining wall they are at that point below about 6inches for about 2-3 feet in length.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
