Thread: Need size for odd ball autopilot cell manifold
    So I was in the process of replacing my tri sensor on my autopilot manifold. I dropped the manifold just right and it broke at the elbow. I built a replacement with a male end of a 1 1/2" union. It did not fit. The union size was too large. Obviously, the union fitting that the cell female end thread onto is not a standard size. What size union do I need?
    27' round Above ground w/sand filter
    17100 gallons calculated
    Nashville, IL
    22,553
    Re: Need size for odd ball autopilot cell manifold
    Unfortunately you have to get it from Autopilot.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Quote Originally Posted by dabaxter
    Yeah, some manufacturers use proprietary thread sizes among other things, so you have no choice but to buy another one by that same manufacturer.
    Divin Dave,
    I was able to recover and reuse the fitting using this method: http://www.youtube.com/watch?v=CfezjNDNxNo
    I had to repeat a few times, but it came right apart, just like in the video.
    Nashville, IL
