Results 1 to 14 of 14
Thread: Im not sure how this is possible?
    Jun 2013
    Southwest Arizona (Yuma)
    125
    Well here we go again Spa is backflowing into the pool. I had this same problem about a month ago so I replaced the check valve and that was the problem.
    So now its happening again? I wouldn't think the brand new check valve would go bad that fast so I'm trying to find out if I have another problem?
    As you can see from the picture there is a Jandy valve on the return and I have shut the valve off to the spa but it is still backflowing? How in the heck is this possible? Could it have something to do with the In floor Cleaning system?
    I can't figure it out
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    Jun 2013
    125
    Re: Im not sure how this is possible?
    I forgot to add that I have taken the check valve out and checked for debris as well and there was nothing.
    My pool:
    22,544
    Back off and take a picture of the entire equipment pad. I don't see anything in that picture other than the check valve that would allow the spa to return to the pool.
    It might be back flowing from the suction side.
    Support the site
    Jun 2013
    125
    Not a great picture but better.
    How could it be backflowing from the suction side?
    This started happening again after the pool guy came on Friday. I think he backflushed the pool but I'm not sure? We are cancelling the service tomorrow and I am going to take care of he pool myself, not just because of this issue but several issues in the past.
    My pool:
    22,544
    You made sure that the check valve was positioned over the port properly didn't you?
    Jun 2013
    125
    Yes I did, and it looks as though the valve in functioning properly?
    My pool:
    If the three-way valve on the suction port does not fully close off the spa, then water could flow from the spa to the pool suction (skimmers and main drain) while the pump is off.
    How fast does the backflow happen?
    Does it happen with the pump on, or off, or both?
    There is a 3/4" line labeled "Aerator". What does that go to?
    Does the backflow stop at a particular level in the spa?
    Support the site
    Jun 2013
    125
    [quote="JamesW"]If the three-way valve on the suction port does not fully close off the spa, then water could flow from the spa to the pool suction (skimmers and main drain) while the pump is off.
    How fast does the backflow happen? Within about 30 minutes after the pump shuts off.
    Does it happen with the pump on, or off, or both? with the pump off
    There is a 3/4" line labeled "Aerator". What does that go to? Its that fountain thingy that you can turn on to flow water from the side of the deck.
    Does the backflow stop at a particular level in the spa? Yes, it stops at the same level it did when I had a bad check valve when it equalizes with the pool.[/color]
    My pool:
    I don't see any obvious reason for the backflow. I'm not sure what else to check.
    Support the site
    Jun 2013
    125
    Quote Originally Posted by JamesW
    I put a new check valve in last night. I'm working today so I will see what the water level in the spa looks like when I get home.
    My pool:
    Jun 2013
    125
    Ok well the check valve I replaced wasn't the problem. So I changed this other check valve seen in the picture and I worked! I have no idea what the purpose of this one is but as long as it works that's all I care about
    My pool:
    Thanks for the update. Good job on getting this fixed.
    Support the site
    Jun 2013
    125
    Oh thanks! It's become my hobby lol!!
    My pool:
