Thread: Amerlite 500W 120V - Cracked Resin
    I have been having trouble with my 2 Amerlites in the pool. The pool is about 8 years old. About 4 months ago, one of the lights stopped working. I pulled it out of the water and it was about 1/2 full of water on the inside of the light. I replaced the bulb, installed a new gasket, and reinstalled the light. Everything worked great.
    About 2 weeks ago, all of the lights stopped working (pool and spa). The GFCI would trip instantly when the lights came on. I pulled out the second pool light (not the one I replaced before) and it too was 1/2 full of water. Dried it out and installed a 40W bulb just to make sure the fixture worked (and no problems with the GFCI) before I reinstalled. However, the GFCI still tripped. Pulled the first fixture out and it had a small amount of water. I opened it up, and noticed that the resin at the base of the fixture had several hairline (non-displaced) cracks.
    After I dried everything out overnight, the GFCI resets fine, and both fixtures work with a 40W bulb, up on the pool deck.
    Here are my questions: should I reinstall everything, or does the fixture with the cracked resin need to be replaced? Is the cracked resin the reason it filled with water in the first place, or is it normal for these fixtures to eventually take on water as the gasket ages? If hot, maybe both of the fixtures need to be replaced? At $200-$400 per fixture, I hope not!
    Also, if I do replace the fixture(s) should I consider the LED fixtures? If one is LED and one incandescent, will the light output match?
    Thanks for any help.
    15,000 gallon IG pebble pool/spa | Pentair 400k BTU heater | Pentair cartridge filter | Goldline AquaRite SWG T-Cell-15
    Pentair IntelliFlo Variable Speed Pump | 3 Pentair Whisperflo pumps (1-2 HP) | Hayward Aquabot | Pentair Intellitouch controls
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Amerlite 500W 120V - Cracked Resin
    Yes the gasket can leak when the light gets old. As far as the cracked resin it could be just the surface crack the resin that seals the electrical cord is one inch thick. You can get an led bulb that will put out as much light as your current 400w or 500w bulb and the led bulb will use less electricity. Good luck with the light repairs.
