Thread: cyanuric acid shelf life
    yzf600's Avatar
    Apr 2013
    Phoenix, AZ
    24
    I moved into a house this summer and found a jar of cynauric acid in the garage. I'm not sure how old it is, but I'm pretty sure it's not older than 13 years as that is when the pool was built. Does this stuff go bad? Note I'm in Phoenix, so the garage temps get to the 100s for several months every year.
    15k gallon, salt water, plaster, Pentair IntelliFlo pump, Hayward 48 sq ft DE filter, Pentair Intellichlor, hayward Aquanat 200 pool vac ultra located in Phoenix, AZ
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: cyanuric acid shelf life
    As long as it is keep dry in a closed container, it should be fine.
