Results 1 to 8 of 8
Thread: putting cover on AG pool with FC level too high
    May 2013
    Paintsville, KY
    42
    I'm closing my AG pool for winter, have vacuumed and shocked with 78% cal-hypo (2 bags- I know I used too much since my CC was .5 or less) and then vacuumed again. My levels were as follows before adding the Cal-hypo:
    • FC-6
    • Ph-7.4
    • Alk-90
    • Cya-45
    Now my FC is 18 and the leaves are blowing like crazy, so I need to put my cover on ASAP so I don't have to clean it all over again. What is the lowest FC level that I can put my solid winter cover on? Please tell me I can put it on now without damaging the cover!!!!
    Intex 24' Round Vinyl AGP(13,500 Gallons), Intex Model 633T Filter Pump with Type B cartridge filter. Taylor K2006 test kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sure put your cover on. Your fine.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: putting cover on AG pool with FC level too high
    I agree. When I close and put on my fine mesh cover, my FC is usually at or close to my SLAM (shock) level.
    Smykowski's Avatar
    Sep 2011
    3,065
    You want it at/near SLAM level so the FC lasts until you open in the spring.
    May 2013
    Paintsville, KY
    42
    I thought that maybe my FC would deteriorate the cover, I'm so glad I don't have to wait for Chlorine to drop back to normal!. I usually don't wait this late to close my pool. So in the morning I'll cover it. I was wondering, should I leave my pump connected for a while with the cover on so I can circulate some 60% algaecide, until the temperature drops to near freezing or just go ahead and drain to lowest hose opening? The water temp. is about 55 degrees. I thought that high chlorine levels will make the algaecide ineffective. What other chemicals should I add, if any, before draining and closing? Thank you all for your help!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you are going to add an algaecide (it is optional and we only recommend polyquat60), then let the FC level drop down a ways before adding it (we recommend down to at least 1/2 of SLAM level). Polyquat is broken down by high levels of chlorine. Again, polyquat is optional.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Mines closed. Brought it up to SLAM level with bleach when water temp was 52. Didn't add anything else. Pump and filter are in basement.
    You would be fine to disconnect pump and filter now. With the pool covered and low water temp your FC levels will hold. Open the pool before the water temp gets to 60 and you should have clear water.
    The polyquat is optional.
    Jeff
    May 2013
    Paintsville, KY
    42
    Thanks guys!! I knew I could count on you
