Results 1 to 11 of 11
Thread: High chlorine demand, slammed the pool 2 weeks back
    Sep 2013
    DFW Metroplex
    119
    I slammed my pool 2 weeks back, chlorine levels were stable for a week, we had small rainfall 3 days back, now again I have high chlorine demand, spending too much money in chemicals . Only thing I suspect is black spots around the pool light fixtures, I don't know how to unscrew and clean those, never done that before. I backwashed my pool 2 weeks back during the slamming process, today I noticed there is a 7 psi increase.
    My Current chemistry
    FC 1.0
    CC 0.5
    ALK 70
    PH 7.8
    CYA 50
    Any recommendations?
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    38,260
    Re: High chlorine demand, slammed the pool 2 weeks back
    Rain does not cause "chlorine demand". You let the FC get too low and that lets things start to grow. Time to SLAM again.
    Light should only require removing one screw on the top of the fixture.
    You should backwash the filter when the pressure rises 20-25% over the clean pressure, likely 7 psi is way too much.
    Sep 2013
    DFW Metroplex
    119
    Thanks, Do I need to increase the Alkalinity to 90 before slamming? This time i want to slam it in a right way to avoid repeat.
    Jun 2011
    Long Beach, CA
    2,780
    You do not need to adjust the TA, but you will need to adjust the pH to the low 7's before SLAMming.
    Which test kit do you have? Without a proper test kit you will not know if you have completed the SLAM and will need to continually repeat it.
    Follow the SLAM process that is linked in my signature.
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by ping
    Ok, I have been using TF 100 since joining TF
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by missourian
    Since you asked about raising TA I thought I would make sure you are using bleach/liquid chlorine to SLAM? We don't recommend trichlor or dichlor to SLAM since both of those add cya and lower ph (trichlor lowers ph more than dichlor).
    Sep 2013
    DFW Metroplex
    119
    Thanks everyone, just cleaned light fixtures, Oh my God, Nasty stuff . I just backwashed and loaded DE, according my filter specifications they recommended to charge 7.5 lbs of DE, I used attached cup, I measured 4 cup as 2 lbs. Is it correct to use?
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by linen
    Yes I am using BBB method, no trichlor or dichlor.
    Jun 2011
    Long Beach, CA
    2,780
    The only time to do a full charge of DE is when the filter is broken down and cleaned. You will only want to add around 75% of a full charge of DE. The most accurate way to know how much DE was added from your measuring cup is to weigh it if you have a scale that can measure it.
    Sep 2013
    DFW Metroplex
    119
    Its 3rd day of my slamming process, my CC is 0.5, water is crystal clear, I loose about 1.5 ppm of FC every 4 hours, as soon as I reach 1 ppm loss for every 4 hours is it safe to call off the slamming process?
    You'll need a drop in FC of 1 or less overnight (OCLT) along with a morning CC of 0.5 or less before the sun hits the crystal clear water. For the overnight test, see: pool-school/overnight_fc_test.
    Don't stop until then.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
