Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: FC HIGH Need to lower SWG??
    Mar 2013
    TN
    178
    ph 7.6
    FC 18
    CC 3
    TA 70
    CH 240
    CYA 50
    thinking i need to lower SWG but it is on 60% and i can't seem to get it to go down by pressing the lower button, it will flash if i hold it in and go to 40 but right back to 60 a minute later
    do i need to something else?
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,418
    Re: FC HIGH Need to lower SWG??
    Which SWG do you have?
    Love TFP? Become a
    TFP Supporter!
    Mar 2013
    TN
    178
    intelichlor
    38,475
    Not sure about the SWG issue, but if that CC is correct, you need to SLAM the pool.
    Mar 2013
    TN
    178
    In my ph tester the yellow side was orange which I consider off scale. Then thee Cc test showed up 3. I am closing pool within next week or so. Do I still need to SLAM it?
    Feb 2008
    Denton, TX
    5,061
    Well, you can SLAM now and then you may not have to do it later. Or, you can close in a week and SLAM when you open.
    Jun 2011
    Long Beach, CA
    2,790
    That test is not accurate enough to say what the FC and CC's are. I'm taking it as those were just guesses on your part.
    We can't say for sure if you need to SLAM or not. Accurate test results is what we need to know. Just guessing, I would leave the chlorine high for now and close it when it is cold enough.
    Mar 2013
    TN
    178
    The tests I did with test kit. I wasn't guessing. I am going to test again tomorrow.
    38,475
    So you have a kit with the FAS-DPD? That was not clear in your posts.
    Do you have automation?
    Support the site
    Mar 2013
    TN
    178
    FAS-DPD??
    My kit came from a link on this forum. A TFP-100 I think is the number.
    Yes I have a pentair automation system.
    You change the Intellichlor percentage via the automation, not the cell panel.
    If you have used non-chlorine shock, that could account for the cc level.
    Support the site
    The TF-100 has 2 different tests for chlorine. One is the OTO test which uses drops to turn the water different shades of yellow to determine chlorine level. The other is the FAS-DPD test where you use a powder to turn the water pink, and then you count drops to determine the chlorine level. Which did you use to test FC? Which for CC?
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Mar 2013
    TN
    178
    I always do all test in the kit and record them. The one with the ph test,OTO, kit usually shows up light yellow and I match it to the appropriate number, the other is with the powder and that one I consider more accurate as it doesn't make me guess the color, that is where I got the FC of 18 and CC of 3.
    Is this the correct way?
    Mar 2013
    TN
    178
    I haven't added any shock.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by gobblerhuntr
    Yes. The 3 ppm of CC is telling you need to continue/do the SLAM process either now or in the spring.
    Mar 2013
    TN
    178
    Ok think I will back the chlorination down to 20% and close pool in a week or so then SLAM it in the spring. Sound good?
    3 ppm CC seems somewhat high unless there is a reason. If the pool has had high use, then that could explain the high CC level. If the chlorine went to zero, then it's possible that bacteria converted some CYA to ammonia. However, that's pretty rare.
    If either of these things didn't happen, then I would suspect test error.
    Either way, I think that I would Slam now to resolve the issue, and not leave it for later.
    Support the site
    Mar 2013
    TN
    178
    Pool has had no use in 7 weeks and haven't seen 0 chlorine. Gonna test again tomorrow and see what that shows.
    Same results and I will SLAM it. Haven't ever SLAMed before so I will have to read up on it.
  20. Back To Top    #20
    Mar 2013
    TN
    178
    Would leaves in the pool have anything to do with it. They are falling here and driving me nuts. I am getting them out but they keep coming
