Thread: Leaky backwash valve issue
    Dallas, TX
    227
    Please see the video. This my dads equipment
    http://youtu.be/Rha-wwFeBeg
    It was doing the same thing with the old valve so he replaced the entire valve and all the o rings and lubricated well. It still leaks. It looks like it starts from underneath the base of the handle. Any ideas?
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    May 2012
    Corinth, Texas
    14
    Re: Leaky backwash valve issue
    I had the same exact problem with my push/pullvalve...replaced mine with this updated design from pentair. as you can see they changed the top of the valve to a threaded on end cap instead of that dreaded set screw.
    http://www.poolsupplyunlimited.com/best ... 7Aod-xcA0g
    IG Gunite pool built in 1994 3ft/5ft/3ft about 10-12000 gallons, Pentair Challenger 1-1/2 hp pump, Pentair TR 60 Sand filter.
    Oct 2013
    29
    get a multiport valve for better functionality
