Results 1 to 12 of 12
Thread: Grill recommendations?
    Aug 2010
    Dallas, TX
    4,052
    Going to buy a new grill. This one will be natural gas (I know, propane is hotter, but I want NG), and I want a NICE one. Got a bonus and going to spend money to get a good one. No Chinese junk, any recommendations?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Grill recommendations?
    Congrats on the bonus!
    I have a Lynx propane grill with a red brass burner and a ceramic infra-red (IR) burner. The red brass burner is good for cooking more delicate items such as chicken and fish but, turned on high, will still cook burgers with just the right amount of searing and grill marks. The ceramic IR burner will sear a steak comparable to the finest steak houses, plus it is adjustable. Many IR burners are either full-on or off. The red brass burner has a higher copper content than the more common yellow brass. Red brass is more durable and is often used in the construction industry and on heavy-duty mechanical parts. Yellow brass is used on more decorative applications. The grade of stainless steel on the Lynx is first-rate.
    Other grills that have a good reputation include Twin Eagles and Fire Magic. These would be two gas grills I would also look at if I were in the market.
    Regardless of brand, I would look for ceramic infra-red burners for the rotisserie and the sear burner. I have had steel infra-red burners on some past grills and they do not get as hot as the ceramic.
    Oct 2013
    Phoenix area
    91
    Been researching for one too. Have you looked at Napoleon and TEC/Sterling? My father in law has a TEC and LOVES his grill.
    Scratched CalFlame of the short list - too many complaints of poor customer service
    Both offer IR, I agree with the above post - ceramic of steel IR.
    304 steel construction is a must.
    Customer service and warranty are a must, you pay for it but you want to have good support 10+ years plus if a grate needs to be replaced, etc.
    TEC/sterling sent my father-in-law a set of new $300 grates after 12 years free of charge.
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
    Jun 2013
    Southwick, MA
    211
    TEC and Lynx are both nice, I have a Weber Summit, but it is now imported like most things unfortunately. It does cook outstanding.
    I actually greatly prefer my Kamado over anything Gas, much cheaper also. I only use the Weber when I am in a rush now.
    24X44 IG Vinyl Custom Shaped Pool, Starite S7M400 Cartridge Filter, Starite Sumpermax VS Pump, built July 2015, TF-100 Test Kit, Pentair Intellichlor IC40 SWG, NG Starite SR400 Heater, Easytouch with Screen Logic, Magicstream Laminars, Bullfrog A7 Spa
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,058
    We went with Summerset. Not as expensive as TEC or Lynx however it seems to do a great job for us. We have ceramic sear burner for steaks and rear ceramic IR burner for rotisserie. Stainless steel #304.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Oct 2013
    Phoenix area
    91
    Brentr, What model # summerset did you buy?
    I looked at a lynx L500(low end for these guys)and a Sole yesterday, both were good and were in the $1500 range closer to where I need to be. So many grills I never heard of!
    I grew up in Jax - actually orange park area.
    13,000 gallon IG
    Pentair equip.
    Attached spa
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,058
    Chris, our summer kitchen came with the TR 32. Hope this helps
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    When I finally get around to doing my ODK, this is one of the grills that I will be considering: http://www.emeraldgrills.com/
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    I have an RCS with double burners. I've had mine for about a year and so far so good. Not the most expensive, but to me the most important parts are the burner design and obviously the BTU output. I've found that many more expensive grills have the exact same burners as the cheaper ones; and in some instances just plain ****.
    Take a look around Lowes...rarely is the burner different on the $250 grill and the $600 one.
    To me the RCS was a nice compromise. Guy who built our outdoor kitchen got us a good discount on it and a free upgrade on the double burners.
    One thing to note is that cooking with NG will take some getting used to. Longer cook times, but you will never run out of gas during a party!
    Jul 2013
    Prosper, TX
    133
    Quote Originally Posted by Brentr
    I have a Summerset TRL 32 and absolutely love it. Have only used it 3-4 times as it was only installed recently, but have no issues with it.
    18,600 gal, IG, Jandy 60 sq ft DE filter, 2HP VS pump
    Stonescapes Tahoe Blue mini pebble
    Oct 2013
    Phoenix area
    91
    Robbie, what grille did you end up buying?
    13,000 gallon IG
    Pentair equip.
    Attached spa
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think he's on the road for biz right now.
    Essential Links:
