Thread: Shooting gunite tomorrow!
    May 2013
    Ocean County NJ
    183
    Had to hold off today due to rain in NJ, hopefully shooting gunite tomorrow! Does the new gunite need to be watered down each day to help cure? I Was told it is important if temperature is hot. We are now in the 40's - 60's. Thanks for the advice
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Re: Shooting gunite tomorrow!
    Quote Originally Posted by HudsonViews
    My understanding is that the water helps the gunite to cure through a chemical reaction and although more important in hotter weather, is still important even in cooler weather.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    May 2013
    Ocean County NJ
    183
    How often do you have to wet it down? Thanks
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Our pool was shot on a day it got up to 27. It was in the 30's in the days following. Our PB told us not to bother watering. I didn't bother. With moderate temps, knowing it can't hurt, why not do it when you can? Below freezing the night they did the coping too. No problems so far.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2013
    Ocean County NJ
    183
    Thanks for reply, I live around 100 miles from build so not able to get there as often as I like. Im trying to make some arrangements so can keep wet.
