Thread: Pool union o rings and strainer basket housing o rings
    New here,been reading a lot,but not sure on this product. I see where I can use plumbers grease on these o rings,but the product I have by Moen says not to use on plastic or rubber?? It is simply called plumbers grease from HomeDepot here in Canada. Any help appreciated TY
    38,370
    Re: Pool union o rings and strainer basket housing o rings
    Welcome to TFP!!!
    You want to use a silicone grease/lubricant meant for o-rings. Do not use anything petroleum based (like vasoline).
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Hayward Jack's Lube or generic equivalent
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    May 2013
    NJ
    114
    Moen plumbers grease is just for brass faucet parts, hence the warning not to use on rubber. Moen also makes silicon grease which is for rubber. Same blue container as Moen Plumbers Grease. Just a different label.
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    Thank you one and all. Mpnret I followed up on your reply,and was able to locate it as described, much appreciated
