Results 1 to 7 of 7
Thread: Now I got air bubbles in the discharge
    Jun 2013
    Southwest Arizona (Yuma)
    125
    Just got through replacing the intake discharge side connections to the pump as well as putting in a brand new pump motor. Well I think I still have a leak on the intake side because although the pump is priming there are still a lot of air bubbles and I have a lot of air coming out my discharges into the pool? Could this be caused by anything other than a leak on the suction side?
    Here's a pic of the plumbing/valves on the intake side of the pump
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Now I got air bubbles in the discharge
    It looks like the pump with the white motor casing has a pretty big air bubble in the lid. I would check the o ring on the pump strainer pot lid. If it is in good condition lube it well with silicon pool lube and make sure the lid fits snug on the pump pot. If that is all good check the above ground pipe joints for leaks. Drizzle water across the joints and watch to see if any gets sucked into them. Also check the drain plug on the pump and make sure it is snug
    Love TFP? Become a
    TFP Supporter!
    30,403
    No. Air in the system enters somewhere on the suction side.
    Jun 2013
    125
    That's what I thought
    Thanks
    My pool:
    38,248
    Do you still see air in the pump lid?
    Did you purge the air out of the filter using the air release valve?
    Aug 2007
    near the swamp
    806
    check the o-ring in the jandy valves, and check around the joints on the suction side with smoke for air leaks
    Jun 2013
    125
    Quote Originally Posted by DBfan187
    I changed the O rings in the Jandy valves but I didn't have anything to use for smoke to check for air leaks. I tried soapy water but couldn't see anything. I had one connection that was suspect so I used Water Weld around it. Everything is working great now. I'm going to buy a couple of the 3 way Jandy Valves and keep them on hand for when I need to rebuild the suction side. But I'm hoping this will work for awhile.
    Thanks for everyone's help on this
    My pool:
