Results 1 to 7 of 7
Thread: What pump to drain pool for winter?
    I have an above ground pool and live in Illinois.
    Need to lower the water level for winter, however I don't want to drain it manually.
    What pump should I get to do this?
    Cost is a factor, however speed is not a big issue. Would prefer to spend around $100 or under, but can spend more.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: What pump to drain pool for winter?
    A small, submersible pump would be a good choice. You could rent one from Home Depot or Lowe's, or buy one from Harbor Freight.
    Love TFP? Become a
    TFP Supporter!
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Here's one from Menards:
    http://www.menards.com/main/plumbing/pu ... c-8673.htm
    Or you could also try siphoning the water out with a garden hose:
    http://www.ehow.com/how_7154397_siphon- ... -pool.html
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    38,472
    Welcome to TFP!!!
    With an above ground pool, I am not understanding why you want a pump and not to just siphon the water out with a garden hose?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As mentioned above rent one for $20-30 per day, or buy a cheap harbor freight pump for $40-$60 depending on sales.
    I could try the siphon method. Never done it before.
    Siphon worked great, thanks for the suggestion and link!
