Results 1 to 13 of 13
Thread: pool light
    pool light
    Hi Ya'll. I just bought a new home with an inground gunite kidney shaped pool. The light bulb is out so i ordered a new bulb. I've drained the pool to just below the light. i removed the one screw on the outter ring, but the ring will not remove. On one side the gunite looks to be halfway up the outter ring. I have no idea how to address this. PLEASE HELP !!
    Re: pool light
    Can you post a picture?
    Support the site
    Re: pool light
    cant post a pic from this compter, it a company computer. I can try to post one from my phone tomorrow.
    Re: pool light
    The whole light assembly should be removable once the screw is removed. The light assembly is a sealed unit with the bulb inside. The assembly comes out on a cord that should reach the deck. Do you know what model the light is?
    Support the site
    Re: pool light
    its an Amerilite
    Re: pool light
    one side of the outter facing looks to be sitting on top of the gunite while the other side is inset deeper into the gunite, so the gunite on that side is up onto the ring itself. About halfway up the sideway of the outter ring.
    Re: pool light
    It sounds like they plastered over part of the light face ring. Most likely, it's only going to be superficial. I will be better able to tell with the picture.
    Support the site
    Re: pool light
    here is the photo. I think i uploaded correctly[attachment=0:373mgwt3]photo.JPG123.JPG[/attachment:373mgwt3]
    Re: pool light
    It looks like they plastered over part of the face ring. To remove the light, you might have to carefully cut the plaster and then patch as needed.
    Support the site
    Re: pool light
    chiseling gunite away form the ring? how brittle is gunite? will it come off in chunks or only where I break it away?
    Re: pool light
    Gunite is the concrete wall. What you see is plaster, which is the waterproof coating. The plaster is usually about 1/2" thick. I would cut it with a diamond blade concrete saw. You can get a diamond tile blade at any hardware store. You can patch any rough spots with white tile grout.
    Support the site
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: pool light
    it doesn't look like too much plaster is on the light. Just take a flat screw driver or putty knife and see if you can get it between the wall and light maybe with the use of a hammer.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Re: pool light
    Ok great. Was thinking of trying out a rotozip with a masonary bit.
