Thread: Which plugs for return lines for closing pool
    Apr 2013
    NW Ohio
    83
    the return lines will still be under water level.
    Should i get the standard white threaded plug with o ring
    OR
    the cone shapped rubber expandable style plug?
    18x37 Vinyl Grecian (24k gals) 8' Inter fab(la mesa) Diving board w/ waterfall & Led, Pentair Laminars & Intellibrite 5g
    Star Rite System 3 Cartridge Filter, IntelliPro 3HP Variable Spd Pump, Max E Therm 400k BTU,
    Pentair Easy Touch 8 & actuators,...Now looking to BBB
    22,537
    Re: Which plugs for return lines for closing pool
    For threaded fittings the threaded plugs with o-rings work much better. It's almost impossible to get the expanding plugs to seal the threads.
    Apr 2013
    NW Ohio
    83
    Ok, sounds good.
    I used the expansion ones in past as well as the threaded plugs. Anything on the threads like teflon tape to keep them from getting stuck come spring?
    22,537
    It may help, but only use a wrap or two. I'd probably just put some pool lube on them if I had it handy.
