Thread: Considering Jandy ePump.....thread sizes?
    Jul 2007
    Allen, Texas
    80
    I currently have a Jandy 2.5hp Stealth pump. I've always thought that it is probably oversized for my system (16k pool, equipment pad is about 15 feet from the edge, with a ~3 foot drop to the water's surface, and the total depth is 5.5 feet).
    I'm considering the Jandy 2hp ePump, to get some savings. I just installed the latest iAqualink controller, so no problems integrating the new ePump.
    However: I've seen a few comments where people had problems with the thread sizes between their old pump and the new one. I really really want to avoid any plumbing changes. The pool builder left very little slack between all the connections. To change the pump mounts would require a ton of re-plumbing work on my part.
    How can I verify the thread sizes? I haven't found any good info yet.
    Thanks, Mike
    Mike
    16.5k IG gunite pool/spa, pebble-tec type plaster, Aquapure 1400 SWG, Jandy 2hp ePump main pump, Jandy 1.5hp Stealth on waterfall, Polaris 280, iAqualink wifi control, Colorsplash LED pool/spa lights
    38,284
    Re: Considering Jandy ePump.....thread sizes?
    Here is the Stealth Pump spec sheet:
    http://www.zodiacpoolsystems.com/~/medi ... A6222.ashx
    Here is the ePump spec sheet:
    http://www.zodiacpoolsystems.com/~/medi ... A6219.ashx
    Easy to find on their website.
    Looks to me like the wet end is identical. So you could just pull your motor off and install the VS motor ... might be able to buy the VS motor stand-alone (maybe cheaper than the full pump?).
    Jul 2007
    Allen, Texas
    80
    Thanks Jason....yeah, I found the install manuals and other stuff right after I posted. However, none of the spec sheets get into the thread pitch spec, which is key. Jandy did that switcharoo on the Aquapure salt cells also...required me to replumb for the latest cell. Really silly.
    Yes, the wet end of the Stealth pump is the same as the wet end of the ePump (it even calls it the "Stealth wet end"). However, I haven't been able to locate the pump and controller together as a kit, but I'll keep looking.
    Mike
