Results 1 to 7 of 7
Thread: Chlorine switch
    Chlorine switch
    I curently have an Aqua Rite SWG and have had to deal with an issue about every year with it.
    I am considering eliminating the SWG and switching to a chlorine tablet metering system instead. This has also been the advise of my Pool Man who has done some work for me in the past. What are your thoughts? Pro & Cons?
    30,414
    Re: Chlorine switch
    Chlorine tabs contain CYA. Managed properly, you can make them work but the most common chemistry issue we see on this forum is excessive CYA from the use of the tabs.
    22,544
    Re: Chlorine switch
    It would help to know what the issue is that you have to deal with. It's highly possible that we may be able to help reduce or eliminate it completely.
    Switching to tablets has it's own problems, as Dave mentioned above. Most people have a lot more problems with tablets that they do with swg's.
    You'll most likely have to drain a significant amount of water every year to keep the CYA to a manageable level and if you don't keep it under control you'll have algae to fight.
    I would either figure out what the problem with the swg is or switch to liquid chlorine, either manually dosed or injected by a pump.
    Re: Chlorine switch
    I have had the unit since 2008 and have had to replace the T cell once and the circuit board twice.
    Now the power aand generate lights are out again but I have readout of the display with no amps.
    I am just frustrated with having to put so much money into my system so often!!!
    22,544
    Re: Chlorine switch
    If you want to try and save it (and yourself some money) read the Aquarite Not Generating thread. You can probably replace the current limiter and get it back running.
    If you want to switch methods of chlorination I suggest you look at an injection pump and drum.
    P.S. If you do decide to get rid of it, I'd like to have it for research purposes. PM me if you want to.
    Re: Chlorine switch
    Thanks but I fixed the problem by replacing the current limiter
    22,544
    Re: Chlorine switch
    Great! It's much better to fix it than to replace it with something new.
    It's amazing how many of those units have the current limiter go bad on them.
