Thread: Current sensing relay recommendation
    May 2013
    Dallas area
    85
    Hello, I am in the process of setting up an acid dosing system with a stenner pump. My system currently has a pentair vs pump, manual valves, intermatic mechanical timer running the pentair swg and pool vacuum pump. This weekend the power went off at the house and the mechanical timers got out of sinc with the the vs pump electronic timer. This made me realize that I could be running a big rick without a check and balance when acid dosing. This is the need for a relay recommendation. I have not been able to find one. The stenner pump is 120v 1.7 amps.
    Thank you,
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    May 2013
    Dallas area
    85
    Re: Current sensing relay recommendation
    Looks like I could use this. Any thoughts?
    http://www.amazon.com/Suncourt-SW100-Cu ... m_sbs_hi_1
