Thread: Open in Tennessee
    Open in Tennessee
    Anybody in Tennessee leave their pool open during the winter?? I've gotten past the majority of leaves falling thanks to 2 pool skims.
    My temperature is presently 56 degrees and I was planning on closing this weekend but my wife enjoys seeing the water versus a green cover. I am thinking that if it isn't harmful to the equipment (outside under eve of house) I may just run all winter instead of closing for approx. 4 mos. depending on how fast spring temps warm up. Any experience/opinions would be helpful as this would be the first time for me running thru the winter in East TN.---THANKS
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    30,426
    Re: Open in Tennessee
    I leave mine open and running every winter. We have been rather mild over these last several years and the coldest I can remember is about 19 F.
    I turned the pump on to run continuously until freezing conditions stopped and, while I developed about 1/4 - 3/8 skim of ice, the pool performed just fine.
    Not sure how much lower than that you could go ( I would guess maybe 10-15 F. if it was for one night only)
    Quote Originally Posted by joel0711
    I'm in Clarksville, and we leave ours open all year. I always run my pump 24/7. My neighbor leaves his open too. I just put a leaf net over for a few weeks to catch the leaves. I also put a few chlorine pucks in the skimmer, as well, since the salt generator doesn't produce at colder water temps. Just my preference.
    20,000 gallon 18x36 Fiberglass with toe kick and sloping walls in deep end
    Sand Filter with Hayward Super Pump
    Raypack Gas Heater
    Thanks for the info..... I'm approx. 45 miles west of knoxville in the ridge and valley area at the foot of the cumberland plateau. I may just leave it going thru the winter. Just checked my temp. and it's still at 60 degrees. I need to wait a little longer anyway. I read that some had used a lite bulb and cover over the pump/filter system when the temps go real low... Sounds like a plan!!
