Thread: Closing Anti-Freeze
    Jul 2013
    Grand Rapids, Michigan
    55
    Closing Anti-Freeze
    Is there a specific type on anti-freeze I should use in the skimmer when closing my pool? I had it closed but the water rose and flooded the skimmer again so I need to pump all the water back down, drain the skimmer with my shop vac then put the anti-freeze back in. I'm just not sure what type to use. I had someone else close the pool this fall so I'm not 100% sure. Any help would be appreciated.
    23,200 gallon in ground pool, Vinyl Liner, Salt Water, Variable Speed Pump Intelliflow 3hp/1.32SF/3.96 SFHP, Filter Pentair FNS PLus DE FNSP36, Heater Pentair Mastertemp 250, SWG Jandy APURE35PLG, TF-100 Test Kit
    22,550
    Re: Closing Anti-Freeze
    You can use pool or RV antifreeze in the pool.
    Jul 2013
    55
    Thank you.
