Results 1 to 7 of 7
Thread: Deciding which to adjust first?
    Oct 2013
    Baton Rouge, LA
    86
    Hi I need to adjust my ph down a bit from 7.8 and bring my FC up from 1.5ppm. All my other levels are great....basically my question is should I adjust these at the same time or one at a time?
    Thanks
    30,000 gallon In-Ground vinyl, small fountain, Polaris 9300 robotic cleaner
    Re: Deciding which to adjust first?
    You can adjust one, and 30 minutes later adjust the other. I'd start with chlorine.
    What are your full test results, and what are you targeting for FC and pH?
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Oct 2013
    Baton Rouge, LA
    86
    FC 1.5
    Ph 7.8 or more ??
    Ta 90
    Cya 30
    I was gonna shoot for 4ppm fc, and to be honest I'm a little confused on what to set the Ph at. My test on the Taylor k2006 read 7.8 but that being the highest available reading I wasn't sure if it was actually higher than that. Any opinions on what ph I should shoot for? Also any opinions on my other numbers I posted are appreciated as I am definitely new to this. My pool is 30000 gallons if that even matters.
    Thanks
    Oct 2013
    Baton Rouge, LA
    86
    Also had a cc of .5
    I wouldn't do anything about the pH of 7.8 unless you have an SWG running or a water feature like a bubbler, fountain, or some sort of waterfall. Those all cause the pH to drift up. But if you have one (or more) of those, or if you think it might actually be higher than 7.8, you could nudge it down. Your other numbers look fine except for FC, which you know you need to raise.
    Did you measure CH?
    It would help us if you put this information in your sig: pool-school/read_before_you_post. Location and pool surface type matter for some of the recommended chemical balance levels.
    Aug 2011
    Cochranville, PA
    228
    I know the more informed then me people say it doesn't matter. But for peace of mind I wonder if you can dilute you sample with half tap water to get an accurate reading on the pH?
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    38,268
    Quote Originally Posted by raidencmc
    No you can not. The pH does not work that way.
